Not sure if I’ve got a full grasp of your situation. I do quite a bit of segmented turning mostly 16 or 24 segment and clearly the best practice is to get the segments cut correctly so that the joints fit as they should. Inverting every other piece is a common but not universally used practice that helps to correct any out of vertical cut. If you are using 12 segments then 6 should go together to make a semi circle. The two ends of this semi circle should sit flat on your table saw or bench. If this is not the case you may be able to rub these ends on a stuck down abrasive and make them parallel. If both semi circles are made into this state then they should go together without gaps. Be aware this can only correct very minor angle mis cuts, the real answer is to cut the angles correctly in the first place, and this is not easy without some practice. Be used mitre saw and table saw with a sled. Both have worked but I find my table saw my most reliable method. I use a “Wedgie sled” in which you do not flip the wood over to cut the second mitre. Using this method I can cut reliably 48 segment ring that will go together first time right off the saw. I know other people can do this on a mitre saw, but I’ve not managed it. I no longer sand my segments other than taking 5he fuzzies off before gluing up. If you are flipping your stock for each mitre cut, make absolutely certain that the stock you are cutting is prepared properly in that the edges are parallel, as you are referencing off alternate edges, and will certainly introduce angular problems if this is not the case. Like other crafting activities, segmenting is a journey, not a destination. Keep t it and you will get there.
