Bosch gts10 which extractor
fraser
8 Nov 2010
Isle of Wight
Hi
I have this saw and am considering also getting the 106pt thicknesser from Axminster. The planer has a 100mm port and the saw a 63mm. I need to buy an extractor which either can be bolted to the wall or has little floor space as I am a bit stuck for free space. A big bin sort of size is all I would probably be able to manage. I wondered what extraction people are using for the Bosch as it seems a bit of an odd size?
Another possibility would be to somehow close the extraction port and replace the open metal piece on the bottom
Of the saw, replace it with a piece of ply and cut a 100mm hole in it? Would this work as effectively?
Chems showed me this
axminster-106pt2-which-extractor-t59842.html
How is this done and which extractor this? Is a mod required to the actual extractor and does pulling the bottom bin out not wreck the cyclone where it looks tight to it and I asume, sat on the floor?
