• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Withdrawn BOSCH GCM 12 SDE Professional *REDUCED*
21 May 2017
Blackpool
£275.00 Collection or Local Delivery £250.00
Any questions just ask, can deliver with 25 miles of FY5 after viewing.
High cutting capacity.
Extremely high cutting capacity 120 mm vertical and 400 mm horizontal enables cuts in very large workpieces
Fast, tool-free saw blade change ensures easy and convenient handling
Has some minor transit damage and missing large fence, hence the price.
See images,
Motor Housing chipped, doesn't affect operation.
The rear sliding lock snapped off, I use a plastic pipe to secure it, again doesn't affect the operation and has never failed.
Thumb push to unlock blade guard snapped but still operates fine and doesn't affect the saw operating.
Only light use, blade less than a year old.
110v, selling as it's just too big for my garage space. Any questions just ask, can deliver with 25 miles of FY5 after viewing.
The most important data
Cutting capacity, 0° 85 x 370 mm
Cutting capacity 0° with spacer (max. vertical) 120 x 200 mm
Cutting capacity 0° with spacer (max. horizontal) 70 x 400 mm
Cutting capacity, 45° mitre 85 x 250 mm
Cutting capacity, 45° bevel 60 x 360 mm
Mitre setting 52 ° L / 60 ° R
Bevel setting 47 ° L / 47 ° R
Tool dimensions (width x length x height) 600 x860 x530 mm
No-load speed* 3,100 – 4,000 rpm
Saw blade diameter 305 mm
Saw blade bore diameter 30 mm
Weight* 28.6 kg
Rated input power 1,450 W
