andrewm
What is the norm for bolts on the second leaf of double internal doors? Just at the top or at the top and bottom? I now have a set installed see How Thick for a Door Frame and and one leaf is going to need locks fitted.
The plan was to use flush bolts either on the edge of the door or on the face (on the other side to the picture). But, at the bottom there is only about 9mm of wood floor under the door before hitting the threshold and porcelain tiles so I may need to fall back onto using a surface mounted bolt which will not look a sleek.
Do I need bolts top and bottom? There is no security issue - but I want the locked leaf secure and not to rattle around as it will be closed most of the time.
Is there any other solution that I haven't found yet?
Andrew
![DSC_1044_01.jpg DSC_1044_01.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/97/97093-DSC-1044-01.jpg)
Andrew
