Boarding up the garage ceiling
Vikash
18 Aug 2006
UK
Hi,
I want to board the ceiling of my garage, insulate, add some more lighting and use the space above for storage. The garage was build about 7 years ago and has a trussed roof. The truss floor timber measures 70mm x 35mm, and is joined over the 5.4m span with metal connector plates. The garage is detached from the house but joins another set of garages (also detached from any houses).
I have been told the roof has a breathable membrane and there appears to be no ventilation holes in the eves.
So here are my questions ;)
1. Do I need to use vapour barrier lined plasterboard, or will normal stuff be ok?
2. As the gap is only 70mm what should I use for insulation? Rockwool?
3. Boarding the top up for storage (B&Q floorboards probably) will it be safe to walk up there and store the usual garage rubbish?
4. Is adding extra lighting from an existing spur(s) notifiable in the garage?
V
i would say maybe not very small joists and plates are for joining trusses not for walking on.
pip
