Best size stebcentre?
Hi I bought a 7/8 in 1997 and am still using it for all the spindle work from 1" sq work to 6" sq table legs, so if it is all you can afford and you need one buy it. Roger C
Hi
Depends entirely on the smallest thing you intend to turn unless you already have an alternate means.
My most used Stebcentre is the 1/2" one which I will use on spindles up to about 2". From 2" - 3" I use a 7/8" and for anything larger I use a chuck.
To be honest, I could do without the 7/8" but not the 1/2".
Regards Mick
