Doug B
Shy Tot
Since getting rid of my table saw & it`s out feed table I`ve been without a router table, as my old T11 was mounted into the outfeed table with a removable fence, shown here.
I`ve been managing since the change around with the spindle moulder or using a router hand held, but my next project requires some table mounted routing & as it`s only going to get sporadic use I didn`t want a dedicated table that will take up a lot of room.
With this in mind I figured a compromise would be a small table that I could hold in the bench vise, but would easily pack away.
The new table would still be based around my T11 & aluminum plate & have the best extraction I could manage, so I started tonight making a housing box for the router.
First off I cut some 18mm MDF to size with the track saw to made the sides of the box & then cut dominos in them.
& glued them together.
The bottom was then cut to size & a ventilation slot routed into it using a 1/2" cutter, 30mm guide bush & template.
The base was then glued & nailed in position.
A 4" hole was cut for the dust extraction with a hole saw.
& 2 more ventilation slots routed opposite this.
The dust port & NVR switch fitted & a spacer so that the box stands level on the bench but still has an over hang to clamp in the vise.
Finally for tonight a test fit of the router & plate.
Hopefully tomorrow I`ll get the table top & fence made.
Cheers.
PS. no chatter was experienced during this build so far.
Cheers.
