PeteG
Hello Lads and Lasses
I've nearly finished the mobile bench I started before Christmas, and I'm looking for some advice and what to do with the top? I was planning to drill a number of 20 mm holes in the top
and then borrowing the orange blocks from the workmate, but no doubt these have limits. I want to be able to hold and clamp things together [ similar to the below links ],
especially when using the pocket hole system, so any ideas would be greatly appreciated. I'm on a tight budget, still out of work since being made redundant at Christmas, so if I can make it, all the better!
The top is made of two sheets of 3/4 inch MRMDF.
http://www.axminster.co.uk/axminster-bench-clamp
http://www.axminster.co.uk/festool-fixed-clamps-mft-sp
