Bathroom mirror frame
Big John
7 Mar 2003
Huddersfield
I'm making a mirror frame and have rebated the back for the mirror and plywood backing. Should I use some silicon sealer to bed the mirror on?
i used to bed my glass/mirror on clear silicone, however be prepared to spend ages cleaning of the silicone!
i don't anymore.....
I would just seal the inside of the rebate with whatever you're using as a finish. As far as I'm aware, bedding internal glass or mirrors is only to stop rattling. So unless your mirror is going to be moved constantly, I reckon you don't need any bedding.
The acids in silicon can also attack the silvering on the back of the mirror so another reason not to use it. If you have not got the mirror yet get it "foil backed" as this not only protects the silvering from moisture it also keeps all the bits together if it gets smashed.
Jason
