whybob71
Hi all
I just received my new Basato4. Yesterday I noticed that when I turn on the saw the blade (after tensioning and tracking it) remain centered on the upper wheel, but it moves in and out on the lower wheel. This make impossible to adjust the guides behind the blade.
It might be the poor weld of the blade (I only tried the one delivered with the saw) and I will try some new good blades.
But it might be also that the two wheels have no co-planarity. This should not be a big problem, since the lower wheel might by finely adjusted (there are 4 bolts for that purpose). I removed the table and with the use of a 50" long wooden "straight" edge placed on the two wheels I tried to adjust both wheels (after tensioning). But this might be not accurate and the blade problem has been only slightly reduced.
Can you give me some advices on fine tuning the co-planarity of the wheels? There is something else I should check and adjust?
I want my saw extremely well tuned and, as I usually do with all my machines, I know that I have to spend time to do it.
