fobco
hi chaps,me again,i have just got a dominion 14"bandsaw,its got a 4 pole motor,its a direct drive no belts,should it be a 4 or 2 pole,what sort of speed should a wood bandsaw run,thanks frank.
fobco":61ovs5d7 said:hi bob,the 2 and 4 pole speeds i understand,but will a 4 pole be ok as a direct drive,or would the 2 pole be more adequate,frank
Tony Spear":2zrmvuur said:fobco":2zrmvuur said:hi bob,the 2 and 4 pole speeds i understand,but will a 4 pole be ok as a direct drive,or would the 2 pole be more adequate,frank
Bob has given you the blade speed you need to obtain i.e. 1 to 3 thousand feet per minute.
You can then establish which is the correct motor by measuring the pulleys that the blade runs around and calculating the peripheral speed.
i.e. pulley diameter in inches divided by 12, multiplied by 3.142 (pi), multiplied by motor rpm gives you the blade speed in ft/min.
The motor that gives you the nearest to Bob's figure is the right one.
e.g for 6" pulley
6/12 x 3.142 x 1425 = 2239 ft/min.
OR 6/12 x 3.142 x 2850 = 4477 ft/min.
So in this case 2 pole is too fast!
9fingers":22p3k89c said:So this is the one you are looking at Frank? http://www.electromotion.co.uk/stockite ... item=47430
It does not say 2 pole motor in the advert but maybe you have talked to them.
Bob
9fingers":35qml7d1 said:Tony,
Frank said it was 24mm shaft which suggests a 90 Frame size which also fits with a 1.1kW/1.5Hp motor as fitted to the one for sale on the website I found.
However I'm still concerned about the speed being too high.
If it were mine I would put on a 3 phase motor and run it from a speed controller. That is what I have on my startrite and with one belt change and an inverter I can do wood or 1/4" steel with ease.
Bob
