Bandsaw Resawing Aid
OPJ
31 Jul 2005
North Somerset
We're all aware of featherboards, but I reckon there's a good chance many of you reading this haven't seen one of this, which uses a small piece of 1.5mm thick (perfect fit in a bandsawn kerf!) plastic laminate (sold dead cheaply as 'plasticcard' on eBay).
This is an idea taken from one of the Wood Magazine books for ideas on a range of woodworking machine; from table saws to pillar drills. The main difference with mine though is that it's designed to be clamped to the table - although I may refine this at some point - where as, in the original design, their idea is bolted to a large MDF sub-table with housing in the base.
You can (hopefully!) see how it works. It's an aid designed to keep the stock tight against the fence when resawing. And, because of the way this plastic bends, it prevents the timber from kicking back at you - not a problem for the bandsaw, I know; but I'll be looking to make some smaller ones for my router table very soon.
It is, however, very easy to put too much pressure on the stock, which can cause it to drift away quite dramatically towards the end of the cut. I may try adding a second guide behind the blade - but I'm concerned there about binding on the blade and not allowing the timber to curl away. Would it be better to position the guide to the side of the actual blade, rather than infront of it?
Obviously, the larger the depth of cut, the greater the height the rip fence needs to be when supporting the stock - especially on thin stuff. I haven't quite finished the large resaw fence I'm making, although I may use some more of this 'plasticcard' on the face.
You may also be interested in the design of this push stick, which I obtained from another book; Success with Bandsaws.
This allows you to keep smaller and shorter stock against the fence using only one pushstick. I added a small wooden knob to mine to help control it, while my left hand applies the forward pressure on the long 'handle'.
One last tip - for correct setting of standard featherboards, trim 3mm off the length of the first 'feather' and set the timber to that against the fence.
Thanks again for taking a look and I hope it may be of some use to some of you. :D
Very nice work.
As to your question, yes the featherboard should be position just in front of the blade.
As far as keeping the kerf open, it isn't as critical on a bandsaw since the back edge won'tdo any cutting nor will it lift the the work as a tablesaw blade could. Still, if you want to keep the kerf open, you could make a table top as was suggestted in that book and fit a bit of that plasticard into a kerf lined up behind the blade. It would need to be on a line parallel to the fence after you've corrected for blade drift of course.
Or, you could make a series of "wedges" using bits of the plasticard glued into kerfs in bits of scrap that you could drop into the kerf behind the blade as you saw.
Thanks guys, appreciated. :)
I really like your idea, Dave, of fitting a small piece of plasticcard behind the blade, which would keep the kerf open behind the cut and, if positioned accurately, keep the cut timber tight to the fence and help prevent wandering.
I'm still looking at making a couple of smaller, overhead ones for my router table and also something quite similar - perhaps using rubber wheels? - to keep the stock tight to the fence on my mortiser... I don't really trust the supplied 'hold-down' nor do I like having even my second hand that close to a moving cutter - mortisers can bite too, you know! :wink:
