Although not strictly a woodworking problem, I've got issues with my nuts...
Replacing the blade on my bandsaw, I noticed the tracking of the lower wheel was forcing the blade forward slightly (towards the door). Adjusting the upper wheel doesn't solve the problem, so I adjusted the lower wheel/hub to tilt it forward slightly, tightened everything back up and nothing had changed. Further inspection showed the lower adjusting bolt has lost it's thread and needs to be replaced.
Wherein lies the problem. I can't get it unscrewed from the nut (which is snuggly nestled in the hub housing), nor can I simply hacksaw the bolt and lift out the nut as there is not enough clearance between the housing and the hub ('hope I've made myself clear - see pic).
So to cut a long story short, any suggestions as to how I can remove the nut from the bolt without having to remove the lower wheel assembly?
Cheers.
Cheers.
