Bandsaw Power Connector
Dibs-h
23 Jul 2007
Bradford, West Yorkshire
I bought a Metabo BAS315 ages ago and looking to get it set up yesterday evening - only to realise the power connector isn't the usual type.
Here's what it looks like from the side'ish,
The whole "casing" seems to stop one of those Commando style (what I assume is a female\socket) from fitting on as they have "flaps\covers" on the end.
Here's one looking straight into the connector,
I also noticed the earth seems to be missing - I suspect that the pin got ripped out somehow in the past & it has the earth wiring right to where the pin would be.
So, the questions,
1. Are all pins much a muchness - i.e. can I buy a plug, dismantle it and transfer the pin over?
2. Assuming the issue of the pin is addressed, where the hell do I get a socket (female) which doesn't have the cover\flap on it, as all the ones I've seen (i.e. http://www.screwfix.com/p/200-250v-mk-c ... ip44/44755) aren't going to fit - unless I "mod" it slightly.
Dibs
p.s. The guy I bought it off had the other end of it terminating to a std 13A plug and it worked fine - so that's the plan for the other end.
I might have a plug for that kicking about somewhere came off of a electra beckum lathe I brought years ago which finally gave up the ghost, will not have time to look until the weekend.
If I find it you are more than welcome to it
By the way I believe the earth is connected by the two steel lugs located on the sides
That would be greatly appreciated - I see what you mean by the 2 steel lugs on the sides of the connector. Might have a quick test this evening with a multimeter.
No rush - just thought it's time I started using it.
Dibs
p.s. Just rung DB Keighley's in Leeds and they have them on the shelf - he referred to them as Continental power plugs. At £15 seems a reasonable price. He confirmed the earth is thru the 2 lugs you said.
Remembered where it was, take a look (photo's took with the webcam), comes in two parts.
Cannot see me ever using it as I have other switches in store so you are welcome to both parts
Chris
Just spent a while wondering round on Google and come to the realisation that these things are called Schuko connectors - common as muck obviously in the EU. :lol: Sorry - I meant in Europe. LOL!
Cool - will PM you my details.
Cheers.
Dibs
