Bachmayr Router
RogerS
20 Feb 2004
In the eternally wet North
"What's that?" I hear you ask.
It was advertised on eBay, new, as a cheap 1/2" router. OK - I've got a DW625 that sits on my 'rat and there it stays. I can't be having with taking things on and off all the time and then resetting them. Even if it is just to hand rout a curved rebate on my garden gate. I've also discovered the comfort factor of having a nice 1/2" cutter rather than a puny 1/4" and so most of my purchases of cutters now are 1/2". OK - OK - I admit it - they make me feel 'professional' :oops:
I'd lost out to several bids on eBay for a second DW 625 and so went for this Bachmayr.
OK - quick review before it goes back. Remember the saying "You get what you pay for". Ne'er a true word was said.
There is a huge amount of play between the plunge bearings and the posts. Some of this goes when you activate the plunge lock but there's a lot left.
The slow-speed startup is OK.
Vibration at full revs (24000) about the same as my Ryobi...nowhere near as good as the DeWalt. On a scale of 1 to 10 the DeWalt is 8, my Ryobi is 3 and this Bachmayr is 4. But the Ryobi has been used a fair bit. The Bachmayr is new.
Turret so sloppy as to be unusable. There is a fine height adjuster (which is simply a plastic insert that unscrews out of the bottom of the plunge height adjuster.). Functional.
There is no lock on the ON/OFF switch. You have to first press a button to allow you to depress the on/off button. The spring is VERY strong and you have to use your full hand to grip it sufficiently. It will get very tiring with use.
It comes with a handful of HSS cutters. It needs to. I saved the best bit 'til last.
1/2"? Nope. Try 12mm. Yup. It's a doodee. Pants is the phrase, I think.
Let's see how easy it is to get my money back.
Chris Knight
14 Jan 2004
SE London - NW Kent
Roger,
That was brave! I do hope you get your money back - I never thought of that in conjunction with an Ebay purchase - perhaps I am just cynical?
Looking up Bachmayr on the web reveals this http://tinyurl.com/ayuym which may go some way to explaining the problems you encountered!
frank
10 Sep 2003
cheshire
roger did you pay with paypal that gives you some protection and if the dealer is a power seller i dont think he will want bad feedback.
can you not use it as a paper weight or a door stop (hammer) (hammer) :wink:
