tsg - I can't see a downloadable manual for the TS-250M, so could you advise whether the saw blade can be changed from the top of the machine, as on the TS-200, please?
I have an earlier Axminster saw of similar type, and I have to turn it upside down for blade changing - what a pain!
Also, it appears that the blade angle is changed using a rotating handle, so fine adjustments should be easier than on mine where I have to change it by pushing on the loosened clamping knob - also a pain. Could you confirm that this is the case?
Finally, I gather from other comments that it has a cast iron table - mine is aluminium, and I have yet to find an angle checking gauge or magnetic feather boards that use aluminium magnets! :shock:
Good luck with your serendipitious purchase.
