Hello,
I made a workbench top from three 3/4" plywood sheets and a sheet of hardboard on top. I want to add a trim around the edge, and I have a 35mm thick Oak trim ready to go. I just want some advice on how to attach.
First of all, is it better to glue or screw? I don't have clamps for gluing and I do like the idea of being able to remove the trim in the future if I ever make a better top and using it on the new table. This is not essential though. I am not sure if screwing into the edge of plywood is a good idea. Plus, would it look ugly?
Also, when attaching the trim, should I use mitred corners or just put them on with the end showing? If doing mitres, what is the best way to go about this, i.e. do I cut two and attach them and fit the others on one by one?
Once the trim is on, it will rise above the top of the bench by a few millimetres. Do I need a router to fix this? Should I fit the trim so the extra millimetres are extending past the bottom of the plywood and just leave it alone? Or can it be sanded/planed by hand?
I realise there is a lot in there, sorry (hammer)
