Anyone any good at maths?
Lancsrick, it's only correct if the down piece is perpendicular... and it's not, it's at 45o so the difference is less than 18mm
But it's not a measurement to the join of the A-D piece, it's the two edges of the top horizontal piece? Which means it is correct?
@The Bear I've realised why Mike and I don't agree on C-F - he has excluded the thickness of the top and bottom horizontals (i.e. internal height is 1150-18-18) whereas I haven't (i.e. internal height is 1150). Whichever is the right interpretation of your sketch will give you the answer.
Apologies, I had thought it was wall to B and wall to A. Probably because I was expecting those two measurements rather than one plus an essentially duplicate one!
Guys
Thanks for all the help I'm pretty sure I have the answer I need now. And sorry for any confusion created along the way.
Mark
This is it in Autocad.
I know I'm not answering the question you asked, but I think a perfectly valid option - when getting other people to slice up (expensive) material for you - is to give them a full-size template (made of card or paper - I like to use heavy lining paper or cardboard for templating, but you can also use thin plastic sheet). For the cutter, they don't need to go through complicated measuring/marking out (you've "de-skilled" their work!) - and if they keep the template everyone can see that the output was "as specified" which gives them and you comfort against accuracy questions/blame later on . Cheers, W2S
W2S
They won't accept a template. Theres no measuring involved on their part, they "just" enter the measurement into a Holzma.
In other circumstances I can see the benefit of a template, or as I acknowledged earlier to Steve M, a rod.
Mark
Folks
Just to say, the back fitted perfectly. Thanks once again for the help
Mark
