Anyone any good at maths?
The Bear
10 Sep 2007
Surrey
Folks
I’m building a cupboard to go against the slopes ceiling in my chalet bungalow. 18mm material. I have settled on some dimensions but can’t work out the knock on sizes. Drawing is a cross section from front to back. Angles are 45 degrees. Can anyone tell me what the distances are A-D and C-F please?
Mark
Um
Numbers are hard to read on my computer
The 4 key measurements on the drawing starting at the top are
196mm
178mm
1150mm
788mm
If that helps
Mark
Can you be sure your walls and ceilings are flat, level and square?
I tend to build frames against walls as I go along, as I am yet to come across square corners in buildings.
Already drawn full size on paper but can’t be sure of the accuracy of my angles and therefore measurements. I’m not cutting the sheets hence I need an accurate number to give
Lurker it’s not intended to follow the contours or the building.
Mark
25.4558mm is what I get. Square root of (18 squared times two).
I don't understand what good it does you since you need the length of B to C to cut the sheet goods that fits between the top and front and when you cut it the other dimensions take care of themselves?
I recommend that you don't mark out from measurements, mark out from marks. Make a rod, full-size drawing on a piece of thin MDF. You can check that the rod fits and then take all your setting directly off the rod, without measuring anything. It is a boon for this kind of work, where a tiny mistake in an angle can throw out something else quite widely.
Steve I understand the benefits of a rod. But I’m not cutting this. There are 2 of these to make. The panels are being done on a professional panel saw I’m told is 0.1mm accurate. So I have to give them measurements
Inspector Pete. I don’t want to sound dismissive when I’ve asked for help but I’m pretty sure neither measurement I need is 25.4mm. I think you have provided A-B
Thanks for the help so far
Mark
Hmmm, I get A-D = 847.8mm and C-F = 540.0mm
Hi
You're starting drawing is wrong I'm afraid.
The two top measurements (196 and 178) are not 18mm apart if the AD board is at 45o.
If you tell me which of the two is accurate, I can tell you the others.
Mark
(homer) Ops! (homer)
Ah I can see that problem now. I can keep either figure and adjust the other to suit. Thick mike which did you use?
Ok. So I’ll go with 196 being correct. Forget the 178
Do we have a consensus with (the not so) thick mike then ?
Cheers all. I knew it was complicated
Mark
Why the lack of love for 196 and 178? If that is the short and long edge of the top horizontal piece then that is correct.
