procell":xvlwb3pp said:You could hire a chainsaw for a day just to slice the logs down the centre with the grain. If you are unsure how to cut them remove the middle section containing the pith as that is what will cause the blanks to crack more than anything. Each log should end up as 2 semi circular pieces and a flat centre piece. You also need to seal the end grain with something similar to old latex emulsion or dilute PVA glue (anything to slow the rate of moisture loss ).
Another alternative is to get an electric chainsaw. I know they are not well thought of in a lot of circles but I have one and it works fine for the occasional job as long as the blade is kept sharp. They are not as brutal as a petrol one so are a little easier to control.
