sparkymarky
Perhaps a sightly different electrical question, and more for any electrical engineers.
I have a boiler it had blown its circuit board.
the supply is on a plug which goes into a two gang socket point the other socket is plugged into a tumble drier. when the tumble drier is turned on or off i have recorded a voltage spike up to 283 volts from a normal 244 volts.
The customer has consulted 3 electricians + western power (national grid) who has done voltage recording on his mains over 8 days and said that although higher on the 240 volt range it is well within limits. all electrics have been checked in the house and have said to be ok.
My suggestion was to install a 5amp supply direct from the consumer unit incase any capacitors on the 13amp ring main (on washing machines ect) was causing interference, but the customers electrician said it wouldn`t make any difference.
I have also consulted a couple other electricians who were also stumped.
Interested to see if anyone has a response to this conundrum.
Cheers, Mark.
Cheers, Mark.
