Dalboy":2xm8lh5b said:... What are the connectors from.
procell":awyu0nrs said:Very nice. just wondering if it will pick up sky channels![]()
tekno.mage":21m2q2q8 said:..... I like the threaded connectors.
CHJ":1m1kq0x1 said:They are something you could do on a wood lathe with a little care, the knurling would be a problem but a series of skew chisel grooves and some coarse sandpaper should do to increase the grip.
Not a lot of patience these days I'm afraid, skill? mostly down to nearly 40 years working in a research environment that helps think outside the box and find easy routes to most tasks, often eliminating the need to spend time perfecting hand and craft skills.gregmcateer":28ry0mb7 said:Very nice, Chas.
Your patience and obvious skill never cease to amaze me
Greg
CHJ":lt7bvhqg said:Came across one being prepared for use over the holidays.
I can see what you mean and did sketch it out as 'lighthouse curve' but it ended up too large a diameter at base or too fragile at top.monkeybiter":3lpr5qhv said:......If I may be so bold I think the central spindles could benefit from more of a continuous curve crossing the platters than is obvious from the photo's, suggestive of piercing the platters. It could just be the point of view though.
woodfarmer":3205nm05 said:.... How do you find working with Walnut? ...
