milkman
Hi I posted on this before a loooooong looooong time ago… how time flies : )
The original plan for these box shelves was to reinforce them with bar set into the wall.
c
Original by markuspalarkus, on Flickr
Sadly my drilling was so bad I couldn't get a neat straight line of drillings, the anchors were loose in the holes, the rods stuck out at weird angles, it was a disaster…
So i decided to support the end using brake cable. I've put a small trimmer between joists in the loft and attached the cable through the ceiling to that.
Shelves2 by markuspalarkus, on Flickr
At the moment I've used cleats salvaged from a ceiling rose light fitting to support the shelves. This is less than helpful though; they are brass, a bit soft and as there's only one screw, the holding won't be that brilliant, the minute some real load goes on there they'll start to slip:
Fwd: Shelves by markuspalarkus, on Flickr
We have an ikea light with this on it:
Does any one have ideas on an off the shelf part like this that could do the trick?
Ideally a barrel in stainless steel with two screws through the side to clamp the wire. Or even better grub screws.
It needs to be adjustable i think rather than a crimp. The whole cable could be tightened from inside the loft but it would be easier to be able to adjust the tension from below as the cable stretches.
I've been racking my brains for something that would help (remote control aircraft boats/model building seemed like a source for a while but no), but can't think of anything. even a name for such a fitting might be.
Hopefully one of you will know how to help so I'll keep my fingers crossed
Marko
c
Marko
