Hi All
I purchased a Sapele gate some years ago cheap and built a side entrance wall to fit it allowing for some 4x2 as posts.
I was thinking if doorstop back then but now want it flush and simple.
I have now ended up with 44mm x 40mm posts ti hang gate on with Hook & Band Cranked hinges.
The only size that will fit the the 40mm posts now are 400mm/16” at 38mm on the hook plates.
Anything bigger than 16”’is 40mm BUt I could cut them/drill new mountings etc etc. and make them for……
The gate is quite heavy and it 913mm W x 1710 H.
I have been told in DIY forums and a reputable gate making company that 16”/400mm is fine for domestic use at this height and width.
Or do fit x3???
Part2 -the gate was originally finished in Sikkens 7 Mahogany ober 10’years and I thought it looked ok as is just a bit dull.
I had it out for a light wash in detergent today and was astounded as how stunning it looked when wet!
So my other point is so I continue with Sikkens 7 Mahogany or will I be dissatisfied at it may not be ‘glossy’ enough.
I have Googled/watched videos and views samples but it looks dull to me???
I have attached some pics which show gate as is, as is with some 4x2 tantalised i was going to use as supports/pillars.
Plus a pic of the gate cleans and wet with a stunning gloss like finish.
Also attached is the pic of width of post with a rule that the hinge pin bracket needs to attach too.
Any thoughts or ideas are MUCH appreciated!
Thanks.
Or do fit x3???
Thanks.
