Hi Guys,
I am attempting to do something, that I assumed was very simple. I would like to add two more double sockets into my garage. Having googled a lot, no one seems to have the same setup as me and all the advice is confusing. So hoping you lot may be able to help:
1) I have a feed entering the garage from the house. This is connected to the main house circuit and only become disconnected when I turn off all the downstairs sockets at the main consumer unit.
2) This feed is connected directly to a 13A Switched Fused Connection Unit
3) from this box, one wire goes to a double plug the other wire goes to a double light switch, controlling the two lights in the garage.
I would like to add another two double plugs off the main feed however I am unsure what the best way of doing this is:
1) Add them in series to the current plug
2) Add another fused spur before the current plug (this would mean, fused spur going into fused spur), then connect all three plugs off this spur
3) Add another fused spur before the current plug (same as above) however then only add one plug to this, and another fused spur, then adding the next plug and spur off this and so on.
4) am i going mad and there is a simple way to do this.
Thanks in advance,
James
Thanks in advance,
James
