oakhouse
Hope that someone can advise
I had a nice Christmas present this year of Axminster pro worktop for router table with fence also a router lift for Birthday ( sounds great )
Trouble is a clumsy arrangement of router fitting and congested access to remove router for plunging
I really had eyes on Jessem system with AUK motor and Mast R Lift plate and here is the question
How easy or advisable would it be to adapt the plate aperature as the AUK plate is 6 mm shorter and around 8 mm wider than Axminster
The table top is plywood melamine top and has a shelf for supporting the plate with tapped holes in the ply shel for assorted fixing and levelling purposes. The existing rebate shelf is around 12mm high and wide
If any ideas or adaptors happy for suggestions from all you experts before I commit to AUk and Jessem and try to sell Axi lift
