TobyDavidson
I had a piece of Yew I had bought to turn a piece for my old craft teacher as a retirement present. When I pulled it out, I noticed a couple of cracks and blemishes which looked a little ominous. Sure enough, as I started roughing out the shape I wanted, a big crack appeared across. The further I went, the worse it seemed.
I thought about putting it to one side, but then thought, 'What the heck, it is all learning. Make sure I stand to one side a bit just in case, and carry on.'
I carried on until a quite large chunk came out, then realised this was an opportunity to practice turning a piece with segment etc. I was not that adventurous with the outside shape, as you can see.
I then turned it round and started on the inside. Suffice to say, the piece did break, but I was so far along I dug out the PVA glue and stuck it overnight.
Lessons learnt
1. a piece may not necessarily be useless because it has imperfections. These can be features.
2. Sharp tools make it much easier.
3. Sanding pieces with holes in takes care
4. PVA can be your friend
5. My M900 could do with being bolted down for uneven or lager pieces.
........and the last one....
even when you are excited, always make sure the chuck key is out before you restart the lathe. I put the newly glued piece back on the lather and wanted to get straight into it.
Luckily, no one was hurt and no damage was done, but it was a simple yet stupid mistake which could have been very nasty
Anyway, here is the finished piece.
It is about 8 1/2" x 2 1\2'
Sanded to 320 and finished with 2 coats or woodwax22
Lessons learnt
