PeteG
I thought this was going to be a fairly easy project I could make in a two or three hours, a 7" Wobble Bowl. The wood is a little thicker than the plans suggested so it stands a bit taller.
I started cutting the base with a Hobbies No5, the cuts were nice and clean and accurate but the blade soon lost it's egde. After finishing the base I swopped blades for an Olson PGT No5.
I've been having problems with tension on the PGT's, when I thought I had the tension right the blade would come out of the top or bottom holder soon after turning the saw on. I kept
playing with the tension until I could keep the blade in the holders, but the downside is, the sections would only remove from above, so the sides were angled. I also ended up with quite
a few burn marks. Each blade would cut just over one section before I had to replace it, but on the last piece I switched to a No7 for cutting the outer circle.
I spent a few hours on the bobbin sander removing the burn marks and trying to straighten the sides the best I could, so each piece is a bit thinner than it should be which didn't
leave a lot of room for glueing. Now it's it had a coat of Wood Silk I'm quite pleased, and hopefully the next one will be easier .
