buzzby
Hi Everyone,
I am about to start a project making a chess set on the lathe out of maple and wenge but I am not sure what finish will be suitable. On a previous set that i knew wasn't going to get much use i had a bees wax finish but i know this isn't hard wearing. I have looked at O.B. Shine juice as an option but not sure how hard wearing that would be and if i used the shelac sanding sealing i have if that would effect it. Have thought about BOL/CA but not had a lot of experience with that and is a bit of a faff plus i know it can catch fire (the rag not the work). Given the shape of the pieces i am not sure the BOL/CA could be applied effectively.
Have used some spray lacquer on a project i just finished which was great but quite expensive and time consuming applying 3 coats over 40 minutes.
Basically I want a nice gloss finish that can be easily applied on a lathe that will be hard wearing and can be applied quickly.
What would you recommend?
