Was cleaning up an Axe head today had to grind the poll with my 9 inch grinder with a flap wheel on it producing lots of sparks
I’ve been storing a roll of super fine wire wool under a near by 10 mm ply shelf near my work bench for ease of use, so cleaned the axe head and didn’t think anything of it.
After this put my Versaflo air fed mask on as some other dusty works to do.
After about an hour or so just happed to notice the wire wool was smouldering and had almost burnt through the ply shelf melting a plastic storage container on top
Luckily managed to pull it out and dump outside and put it out with water but close to going up in flames
There was a strong smell of burning in my workshop but I hadn’t noticed with the air fed mask
Lucky really
Should of moved the wire wool before as noticed some small burn marks whilst grinding with small grinder before
Lucky really
