Doug71
I have a lovely old Robinson mortiser which caused me a couple of problems today.
First problem was while I was using it the big hand wheel suddenly stopped moving the table left and right, this was followed by a thud and a cog rolling out from underneath #-o After struggling dragging the mortiser away from the wall I also found a long tapered pin. I worked out the cog was part of the rack and pinion and it had a hole in the bottom of the teeth which the pin went through but only one way as tapered. After much swearing I managed to get it back together again but just wondered if the tapered pins just rely on the taper to hold them in? I pushed it back in best I could and it seems to be holding.
Got started mortising again and after less then a minute the bit decided to snap :roll: Second question does anyone know if the Harima bits from Axminster are same as the Nakahashi ones, they certainly look to be in the photo?
Actually third question, Mortiser or Morticer or does it not matter?
A photo for no reason except to show what a lovely bit of kit it is 8)
![mortiser.jpg mortiser.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/70/70391-mortiser.jpg)
