I'd keep lookout for cheap overhead projector. You'll wonder how you managed without one when you've used it a few times ;)
Coley
I found one on Gumtree for a fiver and the printable transparencies were cheap. The only thing I found is you need to make sure what you're drawing on is square to the ohp. Easiest way is to draw a square on a transparency then measure the output, then jiggle the ohp till its correct. I've made it sound alot more complicated than it actually is ;)
Have fun.
Coley
