matt
Can anyone give me a rough idea of how large (in litres) a 4oz (or an oz for that matter) bottle of Gorllia glue is?
Ta...
Ta...
Noel":35p4o94f said:Matt, bear in mind a couple of things about Poly glue:
Took me about two and a half years to use about a half of the largest bottle. Would like to have used the rest but by that stage it had gone off
Noel
A very small bottle but the glue is great - I first tried the 4oz bottle as I did not believe it would be that great - it surprised mematt":1kkql3qx said:Can anyone give me a rough idea of how large (in litres) a 4oz (or an oz for that matter) bottle of Gorllia glue is?
Ta...
It's probably like Colman's Mustard - all the profit's in the stuff you waste in the bottle. :?Lord Nibbo":cg73gwbg said:I have this gripe every time I use poly.... why oh why cant it be in a toothpaste type tube so when you use it no damp air can enter the tube!!!! ???
Noel":30l6nzb6 said:Matt, bear in mind a couple of things about Poly glue: one tends not to apply it as liberally as regular wood glues and this in turn means the shelf life can be an issue. I'm only speaking from my own experience. Took me about two and a half years to use about a half of the largest bottle. Would like to have used the rest but by that stage it had gone off and wouldn't flow despite putting a spring clamp on it to try and evacuate the air after using it each time. If I was going to buy Gorilla again I'd get the small bottle. As I said it really depends on your gluing habits, so to speak. I now use Titebond poly which I find superior to Gorilla.
Noel
