johnbs
Let's start with the good: it arrived on the day specified. Bought off E-bay; described as "Refurbished to a high standard. Needs a minor amount of work to tidy up the electrics." Well, that's OK, I'm an elec. engineer.
There are several issue-ettes:
All the interlocks are missing (all electrical components and some mechanical)
One of the four main cover screws is present
The blade, when set to run/track say 3mm from the front edge of the lower wheel, runs 5mm from the front of the top wheel. (Is this important?)
There's quite a lot of crude (metal) embedded in the lower tyre.
Guide issues:
The faces of both thrust rods are grooved, the lower in particular
Because (I suspect) the lower thrust- rod is now too short, the lower guide is skewed: (side view)
The upper guide-blocks were set with the RH one touching but parallel-to the blade. The LH side had been set and run for some time with the tip only in contact:
Now, as I'm new to band-saws, I'm not sure about the precise "norms" for descriptions, but I don't think I'd describe this as "Refurbished to high standard"? Am I being too picky? Do I need to replace the guide block or will it be OK with the tip bevelled off? Advice much appreciated. (Also where do people purchase spares: Startrite quoted some eye-watering prices for the individual guide blocks. )
:? [/img]
PS is there supposed to be a brush somewhere which removed crud from the blade (as opposed to the lower tyre?)
Guide issues:
:? [/img]
