AndrewC
I'm building a hinge which needs a wooden hinge pin. This is a fairly hefty piece and the pin needs to be pretty big. Got everything shaped, drilled out a 19mm diameter hole for the pin (I had a 19mm forstner bit), went down to the local shop and hit a brick wall - no 19mm dowel. They jump straight from 18mm to 22mm. Hmmm, what are standard dowel sizes ? Is it a waste of time looking in different places ? Anyone know where I could mail order about 15cm of 19mm dowel ?
Grumpy Andrew
Grumpy Andrew
