 Reply
By Alder
#1278161
I am not over enamoured with gripping ability of the fence on my Metabo bandsaw. I have a spare fence off an extinct Elu tablesaw but it is wrong handed.
Does anyone use a fence from the reverse side to the conventional side, provided it is long enough of course?
Russell
User avatar
By Lazurus
#1279203
I have my fence on the R/H side of the blade, it is then easy to remove if required, how do you mean "grippy" is the fence moving from its position on the table?
By Alder
#1279280
Yes, it can and does move from its place on the table hence the question. I have know tried the alternate fence on the opposite face by merely clamping it on, and this has given me a degree of success. I will make another attempt with a Bessey Klick clamp which is possibly more suitable for the task than the one i did use. (aldi)
Russell
User avatar
By MikeG.
#1279282
I made a secondary clamp for my bandsaw fence (at the opposite end) with a powerful over-centre catch, and fixed some non-slip stuff to the underside. Between the two, the fence is now rock solid.
By Alder
#1279315
It is the over-centre catch which is the cause of my problem. I will look to try your solution Mike.
Thank you.
Russell
By Alder
#1279375
I have a piece of used Abranet under the over centre catch and the grip is more solid.
Once again Mike Thank you
Russell.
