 Reply
By nipper7657
#1241250
Hi,
I have a Record 24" lathe which I have had for about 20 years. I was in the forces and have moved a lot. At some point, I have mislaid my hollow tailstock centre which I used for centre boring (I have the boring tool which is 7mm thick). I can't seem to find any references to the centre anywhere that would enable me to buy a replacement. Anyone got any advice please?
User avatar
By Jonzjob
#1241454
I have a Record CL1 and the Axy live hollow tail stock centre and they go together well. I also had a drill bit welded onto a length of steel rod, put a handle on the other end and that works a treat too. You still have to pull it out and clear the lands regularly, very regularly.
The one you have linked to is not a live centre Trevanion, this is the one I have but mine is older and without the chip holes. :mrgreen: :mrgreen:
https://www.axminster.co.uk/axminster-e ... n-ax923985
User avatar
By Jonzjob
#1241522
They don't appear to do a 1MT version? That's what's on Nipper's lathe.
Plus, there's always the chance of a customs tax on stuff from over the pond. :shock: It does look a useful bit of kit though.
By Inspector
#1241581
I am not familiar with the details of the lathe and didn't know about the taper size. None of the Nova lathes ever came in a number one Morse taper so that would be why they don't offer that size. The Nova stuff is available in the UK and thereupon of the link to New Zealand was because they had the best description. No problem though as the info might be useful to someone else.
User avatar
By Jonzjob
#1241595
I'm sorry if that came over as a bit detrimental Pete. There was none intended mate :mrgreen: :mrgreen:
The reason I know the MT taper is because it was my first lathe.
