rafezetter
Troll Hunter
Can anyone recommend a low odor quick(ish) drying filler that is specifically waterproof, other than car body filler / 2 part epoxy types.
I previously used the normal style, water based ready mixed filler to fill a 25mm x 15mm deep gap between window cill and window frame, but the last tenant in the room allowed a significant amount of condensation to build up and it turned that filled section to mush.
I was considering car body filler, as I've used that before to great effect, but the smell is strong and offputting.
I've been suggested plastic wood, but I have not used this and have no idea how it will react if the same issue occurs, and I'd rather not have to revisit this particular problem a third time.
I'd appreciate any advice you may be able to give
