- Joined
- 11 Mar 2009
- Messages
- 1,315
- Reaction score
- 11
I have a Metabo HC260M thicknesser and it has been a real work horse. I was just reading an article on the inter web on checking alignment of the planer tables and the thicknesser and thought that I would check the machine as I recently noticed the stock was not totally square.
So I set the thickness to 20mm and ran two small pieces through one each side to check the lower table. Seems that there is ~ 0.5mm difference between the 2 sides and I cannot see how you can correct this ?
I have been wanting to upgrade the machine, but I can't afford to do so at the moment.
I am also about to replace the rubber feed roller as that has worn and causes the timber to not feed. If the machine is beyond repair then I may just have to bring the inevitable purchase forward.
