Taffy Turner
Here's a little tip for you guys having trouble with your patterns either not sticking, or being impossible to remove.
I had hours of fun when I started off, as if I only gave the pattern a light spray of adhesive, the it would lift half way through cutting. If I gave it a heavy spray, then it would be almost impossible to remove.
What I do now is cover the wood completely with B+Q clear packing tape, and then glue the pattern to this. That way I can use as much glue as I like to hold the pattern down, but when I am finished, the tape peels off the wood really easily, taking the pattern with it.
Also, apparently the plastic tape helps to lubricate the cut and stop the wood burning so I am told.
Regards
Gary
PS - I suppose just about any type of packing tape would work, but I have found by trial and error that the B+Q clear one has just the right amount of "stickiness". I tried a cheap brown tape first, and that was too sticky and pulled a lot of fibres out of the surface of the wood when it was removed.
Regards
Gary
