Machining lignum.
woodywoodwood
7 Dec 2017
north of m25area
Evening all.
Having read the posts about Stanley routers, and variants, and seen Derek's obscenely good looking ( but does it work??? :wink: ) router, I have decided to use one of my collection of bowling balls to make one too!
I remember some years ago cutting some particularly hard purple heart on the bandsaw, and wrecking a blade.
Does anyone have any advice for me on how to cut the piece down? It is a complete ball, so will need some careful holding , or an edge planing to it, before cutting on a machine. Or should I handcut it?
I'd rather not wreck any other blades. I have a few bowling balls; should I use one that looks like it has a lighter coloured section, or just use one with all heartwood?
Any thoughts appreciated. Thanks guys.
Www
PS - I believe the wrecked blade was caused by the hardness of the wood, rather than poor practice. I use a bit of purple heart, and this bit was something else. It was like metal!
Ah, Pete, thank you very much for your post. The clamp looks good - that's what I'll do. Can I ask whether you ever used a table saw?
I am loathe to pipper up the blade on the big bandsaw - do you think an inca 260 will handle it?
Or am I over concerned? Just do it?
Thx again
Www
The blade should be o/k I never had any trouble cutting across the grain with mine, I wouldn't use the table saw its far to dangerous, you will have a lot of unsupported wood it it catches it will pivot into the blade and cause mayhem.
There is a hole at the top and bottom of the Ball-o-matic 2000 to help clamp the ball.
Thanks folks, will post some wip's when I go for it.
I have the Dakota pro grip resaw jig. It is the right angle clamp thing that slides across the BS table. I might give that a go. Hhmmm.....
