alanjm
Has anyone ever replaced a hegner table (made it larger) with one they have built themselves? (Not as a false table that fits over the original table)
Alanjm
Alanjm
Gosh, wasn't that helpful of them :lol: ?alanjm":1ghpegq6 said:... i then spoke to Hegner who suggested I move up a saw or two (I have a multicut 2S) ...
Gill":3awdzthj said:I've just looked at the table on my Hegner and it's mounted on two small separate bolts that are aligned with each other along the length of the saw. They are fitted with friction washers to inhibit the table rotating. In theory, you could remove those bolts and replace them with a long piece of threaded rod which would hold the replacement table in position. In practice, I'd be concerned that there would be a propensity for the replacement table to roll if even a slight pressure was applied off the centre axis.
Gill
