Some bloak
After postponing for a long time I'm just getting stuck in to my first new workshop build in an outbuilding. Walls are being covered in a heavy DP membrane followed by 3 x 2 stud/ batten frame, which is then being covered (not in between the battens) in 50mm Recticel, finished by cladding the whole lot in 18mm OSB. So far so good.............
However, I'm not sure about the floor. I've found and followed lots of good threads here about flooring but I can't quite match up any with my proposed method. I want to construct a batten/stud frame out of 3 x 2 (400 centres and plenty of noggins) to the existing concrete floor, again with a heavy DPC membrane over the concrete before I frame on top. I Then want to cover the 3 x 2 floor frame with the 50mm Recticel, then everything covered over with a floating 22mm P5 chipboard. I tend to favour flying all insulation over/on top of wall and floor framing rather than in between to minimise thermal bridging where possible (or is in between or on top of a negligible difference?)
The last minute doubt I have, does anyone think that the Recticel will compress detrimentally onto the 3 x 2 floor frame underneath or will the floating chipboard spread any machine loading sufficiently not to cause any problems?.
The concrete floor dips in the middle and is generally not level, otherwise I would just float the Recticel straight onto the concrete to start with. The 3 x 2 battening method will allow me to pack out where needed to get the floor level, plus the 3 inch depth between the battens will give me a handy service void for bringing any cabling to machine points in the workshop if I choose to. I've thought about some sort of levelling screed, but at 30 square metres, it could be expensive and more time consuming than knocking up a batten frame for everything to sit on?.
Any opinions, ideas or previous experience on this, as always will be gratefully received. Many thanks everyone.
