PeterBassett
Hi all.
I'm in the process of turning my garage into a "Workshop" or sorts.
It's about 10x20 ft.
Can I ask some electrical questions?
It currently has two fluorescent strip lights and one double socket powered off of one 13amp spur from the house.
I've got a quote from a spark and he has said he can run a new 32amp supply to the garage with a small garage board for £350.
Does this seem reasonable to you? Does a 32A supply seem enough?
It would be an armored cable ran around the side of the house and under a small section of patio. I except I'll have to lift the patio my self.
At the moment I have a DeWalt 1501 radial arm and a small 1kw record dust collector.
Once the supply is upgraded I would put at least two ring mains. I would like to be able to isolate the radial arm so it can only be turned on with a key.
Three separate lighting circuits each with two strip lights. One set for each section between the two roof supports.
Once it is all in the spark says he'll test and certify it.
Does this sound sensible?
Any good suggestions or advice would be most welcome!
Pete Bassett
Pete Bassett
