Spindle
Hi
Another garage conversion thread I'm afraid but having searched and read through other relevant posts I still have a couple of questions.
I have a 6m x 6m double garage, block wall construction with a tiled and sarked gable roof that I'd like to make more enticing to use in the winter by cladding and insulating. I've started to research installing a ceiling onto the roof trusses, the rafters of which are 95mm x 38mm @ 600mm centres.
I've read plenty of recommendations to use OSB but am wondering what thickness would be best, could I get away with 9mm? In a similar vein I have noticed that at some thickness' MDF is cheaper than OSB, is there any reason not to use MDF? MFD appeals to me as I believe the surface finish would look better when painted. The garage does not suffer from damp.
Once the sheeting is up I would plan to insulate with 100mm fibre glass, is this reasonable?
I'll stop there for now because I'm sure I'll be back with questions about cladding the walls.
Regards Mick
Regards Mick
