tom owens
hi all. im hoping for a bit of advice if anyone could help me... iv made some kitchen doors out off u.s oak,european oak,walnut and maple. i made one of each in various sizes with rail and stile joints and a solid floating panel to suit. iv got the panel to fit snug in the hight but slightly loose in the width for expantion... all the timber is kiln dried but after reading a thread just now about moister content in hardwood i think iv made a big mistake... as soon as i got back from the timber yard i started machining the timber to finished size. then i cut all the timber to rough lengths and run it through the spindle to cut the joints. so to cut a already long story short i had all 4 frames put together dry and the panels gluing overnight in a cold workshop. all the panels dried fine so after a sanding down and a run through the spindle to put the profile on the raised panel and another sanding i assembled,squared and glued my doors up. are these doors eventually going to warp and twist in room temp now iv made them without letting any moister in the timber dry out? could someone please explain the whole drying out of timber so when i make something and bring it in the house its got less of a chance of twisting... if i make a cupboard in my shop with a small heater in it set at room temp to leave timber to dry out would this work as long as the heat dosent escape?
