Woody Rebate Planes....
DTR
11 Mar 2011
Essex
.... are vicious little pineapples. Am I the only one who loses a chunk out of my hand every time I go near one? :oops:
I think it's because the blade on mine is a bit wider than the body, so the left-hand corner sticks out a bit.
You're not alone. I hardly ever cut myself woodworking but my favourite skew rebate has got me more than once, just picking it up.
Your blade might need grinding down - a little.
The blade must NOT be narrower than the body (obvs) and it's tricky to make it exactly the SAME as the body, so they tend to be made a little bigger than the body. This is true even for current day metal shoulder planes.
However, your wooden rebate body may well have shrunk a little over time, leaving the blade too proud, a well known sin, :D
BugBear
I thought that it was just me.
The blades of rebate planes, whether wooden or steel, MUST extend a hair outside the body. This is to ensure that the blade planes into the corner. A plane with a flush blade, or one that does not extend enough (thin hair?) will leave a stepped rebate behind.
And ... yes ... I always cut myself, especially skew bladed versions, forgetting the edge is there ...
Regards from Perth
Derek
The metal ones are just as bad with the honourable exception of the Stanley 78, which has the fence arm extending to cover the end of the blade.
Funny. Having had two severe lacerations of my left thumb over the years I'm certainly tempted but a leather glove probably wouldn't have helped me much.
The worst cut I've ever had happened when honing a spokeshave iron freehand without a holder. Make a holder.
