Quantcast
Wooden Garage Doors
stuartpaul
11 Feb 2003
Somerset
I'm going to change the old metal up and over to a set of new wooden doors similar to these:
http://www.longmangates.co.uk/farley.html
It's a panelled design as opposed to framed, ledged and braced.
Going to use softwood and ply and then glaze and paint.
Having some difficulty getting the timber sizes I want so thinking of laminating to achieve what I want.
Anyone see any problems further down the road if I do? Would almost certainly use a high quality adhesive to do this (West or similar).
Davidadew
15 Jun 2009
I did this sometime years ago before we moved (using different doors), gave me much more space as didn't have up and over door getting in the way. Only problem I had was that the timber expanded and contracted too much causing problems with the locks not meeting; I should have researched this more.
stuartpaul
11 Feb 2003
Somerset
Bradshaw Joinery":3egc9cl6 said:
Hi Stuart,
Could i ask what timber sizes your struggling to find? and what wood it is your after?
Generally the larger sizes for the frame - 150 x 75.
Also aware that buying softwood from the likes of TP etc. can be fraught with problems so looking to try and use redwood.
Even 150 x 50 can be a problem unless I want to make curved doors!
I've got TP, Bradfords and Jewsons to chose from locally.
Bradshaw Joinery
13 Mar 2012
Market Harborough
I Am sure if you asked the likes of any of them they could get the redwood you need in to do the job. I find the smaller merchants better to deal with tbh. Or maybe a joinery shop could add the timber into there next order.
Id probably go ex 100x75 Frame and door stiles/head of 110x45. mid and bottom rails of 220x30, and braces 110x30.
the tg and v boarding i assume they would stock anyway. ex 19x125 tgv.
Quite lucky here as whe have a both hardwood and softwood suppliers within 5 miles.
If your painting or staining dark id suggest sending them off to be green treated.(tanalised) once everything has been dry assembled/cut to size. Obviously if you have acces to the services nearby.
jasonB
26 Nov 2004
Surrey
150x75 is a standard redwood stock size so any decent timber merchant should be able to supply.
Thats quite thick for garage doors they are usually ex 63mm otherwise you have to have a steep leading edge which can give a big gap on the inside.
J
stuartpaul
11 Feb 2003
Somerset
Mmm.....
I may have been over engineering a bit!
Certainly need to have a beefy frame and if I can I will go with 100 x 75.
Would 50 x 100 be OK for the rails and stiles with 18 mm ply for the panels?
