wood polishing(pens)
jonesbones
27 Aug 2011
eccles
which is the best way to polish wood in paticular and acrylic in pen making . Are polishing mops with tripoli compound g52 the best or micromesh? hut crystal polish hut acrylic or as something better come on the market I cant think of a better way of finding out than asking you dedicated woodworkers I know this will have been asked before but you never can tell cheers jonesbones
My wood pens I finish with BLO/CA finish after sanding to 600grit and my acrylic pens I sand wet down to 12,000grit no need to polish after that. The only thing I do is give both a coat of Microcrystalline wax.
I do not use my buffing system to finish them. Others may use different finishes on theirs
HERE is an acrylic/polyester pen I did recently
Exactly the same as Derek though I sometimes take the wood depending on hardness (lig vi for example) down to 1200g and I rarely use blo with the ca.
I do sometimes spray on a couple of coats of acrylic sanding sealer before the ca if the wood has an open grain like oak.
