I echo some of the comments above:
Amazon customer service - I've found then superb (3 times), so IMO, no problem there;
That particular drill - maybe OK, a lot depends on what you want to do with it. The chuck size is nice and big (16mm) and the 3 mm smallest is not a big problem in my experience, you just fit a smaller chuck, either direct on to the quill, or buy a separate small chuck complete with hex drive shaft and chuck it into the big chuck (about ten quid). But the motor is a bit small at 500 Watts (my Rexxon "only" does up to 13 mm and is 650 Watts). Biggest problem is that until you get your hands on it, you won't know how good the chuck is, nor the quill (run out);
Aldi & Lidl - again personally I've had a lot of success with Parkside and Workzone tools - generally fantastic value for money, but of course, they ain't Festool, etc quality - far from it. But they work/do the job, and again a lot depends on your budget. I've also had a couple of duds, but found their no-quibble guarantee just that - absolutely faultless.
In short, if that's your budget and can afford to wait, buy second hand (you can check run out before buying);
if not, then buy where you can take it back easily if there's a problem.
I THINK that just about all new drill presses at that price are going to be much of a muchness, and most probably come from Asia (though IMO, coming from Asia doesn't necessarily mean junk).
HTH, good luck.
AES
